2000 Toyota Camry 2000 camry Oil Leak
204,768 MILES • 4 CYL • FWD • AUTOMATIC
LINCNLVR
My engine is leaking from the rear at a pretty good rate went 120 mile and was down two quarts. I need to know where the oil sending unit is on this thing. Is it on back side fo the engine near the firewall? I had noriced a leak but not bad un till I Changed the oil, this vehicle has been maintained as per the schedule with now problems until now.
Jul 26, 2009 at 5:54 AM
STEVEW84
  • 673 POSTS
the oil sending unit is on the front of the head. I would probably jack up the car and see where the oill is leaking from first. If I had to take a guess, it is probably coming from behind the timing cover.
Jul 26, 2009 at 9:30 AM
