2000 Toyota Camry
SOXERPOXER
  • 2000 TOYOTA CAMRY
  • 4 CYL
  • 88,000 MILES
Battery is good has been tested, still have trouble starting. How do I know if it is alternator or starter?
Thursday, May 27th, 2010 AT 8:41 PM
Is it cranking over and will not start or just won't crank at all/nothing?
Sunday, May 30th, 2010 AT 6:28 PM
SOXERPOXER
Oh it cranks over, but it is a hit/miss situation.
Sunday, May 30th, 2010 AT 7:15 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, May 30th, 2010 AT 9:23 PM
