Hi there,
You can purchase a timing beth kit, this will give you all the parts you need to do the belt job, as for the water pump, the pump & gasket will come together, you may wish to replace the thermostat at the same time, so get this and a seal and also get the correct Toyota coolant from the dealer.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, May 26th, 2009 AT 12:47 AM
