1999 Toyota Camry wipers
30,000 MILES • 4 CYL • FWD • AUTOMATIC
KINNEY
My wipers keep skipping across window although I have changed blades
Dec 13, 2007 at 7:52 AM
  • 31,937 POSTS
Hi there,
Clean the windscreen with a good quality glass cleaner, and use good quality blades, cheap blades form chain stores are just that, cheap and nasty. You may need to increase the pressure on the blade slightly, ask your mechanic to do this as if to heave the wiper motor may over heat and you will also get a squawk with a partially damp screen.
Mark (mhpautos)
Dec 13, 2007 at 8:05 AM
MERLIN2021
  • 17,250 POSTS
Tyr the new carbon composite blades, I agree with Mark on blade qualitry, My wifes Hyundai needed them to run quiet!
Dec 13, 2007 at 8:10 AM
