1999 Toyota Camry Where is the throttle position sensor?
123,000 MILES • 6 CYL • FWD • AUTOMATIC
HENRYDHIGGINS
My engine code according to AutoZone says there is a problem with the throttle position sensor, either
1. Sensor open or shorted -- replace it.
OR
2. Check connector and wiring.
Where is it? Can I service it myself? I am competent with basic jobs, I've changed my O2 sensors (front and back) but I don't want to undertake any major disassembly by myself.
Thanks,
Henry
Feb 12, 2009 at 4:14 AM
F4I_GUY
  • 3,302 POSTS
The TPS is located on the throttle body. It usually is a 3 wire plug. On some models the TPS is non serviceable and you must replace the whole throttle body. Hopefully, this is not the case on your particular model.
Goodluck.
Feb 12, 2009 at 12:43 PM
