1999 Toyota Camry wheel barrings
138,000 MILES • 6 CYL • FWD • AUTOMATIC
LEVIBIGRED2010
i have a 99 toyota camry the wheel barring on the rear i'm wanting to know how it comes apart like is it pressued plated together do u know were i can fine a digram or send me one thank u
Mar 25, 2010 at 9:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1905.jpg
Mar 25, 2010 at 11:44 AM
LEVIBIGRED2010
how would u do it if u just have the whell barring can u show me a digram to see how it comes apart or like the step after u take the abs sencer off does it have to be pressed on and off
Mar 25, 2010 at 9:32 PM
BLUELIGHTNIN6
  • 16,542 POSTS
does your car have ABS or not equipped with it ? If it has ABS then you have bought the wrong part, because the ABS style rear wheel bearing can not be separated, you must purchase the entire hub. If it is not equipped with ABS than you have to use a bearing puller to separate the bearing from the hub.
Mar 26, 2010 at 6:14 AM
