1999 Camry Idles slow on startup when engine is cold. It dose not stall. It idles fine after it warms up.
Wednesday, June 18th, 2008 AT 3:02 PM
KHLOW2008
MECHANIC
Hi cabothines,
The IAC should be stuck, does the check engine light shows?
SPONSORED LINKS
Friday, June 20th, 2008 AT 11:13 AM
CABOTHINES
MEMBER
No the check engine light does not come on.
If I drive about half a block it will then idle OK.
Friday, June 20th, 2008 AT 12:23 PM
KHLOW2008
MECHANIC
Hi cabothines,
The cold start system is not operating properly so you need to check the Idle Air Control or Fast Idle Control depending on which system is your car equipped with.
