1999 Toyota Camry Removal of cv axel
205,000 MILES • 4 CYL • FWD • AUTOMATIC
DCRITT
I am removing the passenger side cv half axel. I am free from the wheel, have removed the bolt and the snap ring from the middle of the axel. I can't get the axel out of the transmission. What else do I need to do?
Sep 29, 2008 at 9:13 AM
DOCFIXIT
  • 18,828 POSTS
Hi dcritt
take a big pry bar place between CV joint housing and the trans. Take care of the seal and with a thrusting movement dislodge the axle.
Good luck
Thanks for donation
Some trans fluid may leak out check and top off.
Sep 29, 2008 at 9:22 AM
