1999 Toyota Camry Radiator overheating
MEWSICMASTA
Engine Cooling problem
1999 Toyota Camry 4 cyl Front Wheel Drive Automatic
Hi. I have a 99 Toyota Camry LE and the radiator was cracked. I changed the radiator and noticed that the cooling fans do not come on. They did not come on before the radiator was changed. How do i troubleshoot this? Is is the relay? Fan? Motor? Please help. Thanks!
Apr 18, 2008 at 1:01 PM
MASTERTECHTIM
  • 4,750 POSTS
first you need to check for power and ground at the fans when engine is hot. if you have power and ground then the fan motor is no good.
Apr 18, 2008 at 1:09 PM
