1999 Toyota Camry problem with TPS sensor
MIKE.G
Engine Mechanical problem
1999 Toyota Camry 4 cyl Automatic 190000 miles
like i'm not very good with my english, i'll try to explian myself the best i can.
when i turn on my engine, this starts with 2000 RPM in parking mode. when the engine is in drive mode and i stop, it starst shaking and the RMP goes to 800. my mechanic told me that it is the TPS sensor (throtle position sesnsor i belive) and it should be replaced. i want to be sure.
Apr 17, 2009 at 6:54 AM
BMRFIXIT
  • 19,053 POSTS
Its not the TPS but its the idle air control valve have to remove it and clean the carbon
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 17, 2009 at 2:10 PM
MIKE.G
also i went to autozone for scan diagnostic due to the light "check engine". after that, the guy told me to check the "forth spark plug" (i'm translating this from spanish "bujia") and the wires around it
Apr 17, 2009 at 10:11 PM
BMRFIXIT
  • 19,053 POSTS
yes , you need a tune up,
should do a tune up for sure and change it all
plugs wires all ,
Apr 17, 2009 at 10:41 PM
