1999 Toyota Camry Possible Timing Belt Problem?
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
SLIM98
Hello. I tried to start up my 1999 Camry tonight and she wouldn't crank. Symptoms are as follows:
- I put the ignition switch to the "On" position and I heard random clicking and buzzing. The dashboard lights dimmed, brightened, then dimmed again.
- I pulled the key out and the hazard blinkers turned on -- though at a low brightness level.
- I get absolutely no mechanical function - the break pedal is stiff and it seems as though power to it has been cut off.
- Only the lights work - the power door locks and power windows do not work.
Seems like a timing belt problem to me given the mileage and symptoms. Any opinions would be much appreciated -- including repair cost estimate if it is indeed a timing belt issue.
Sep 27, 2008 at 9:37 PM
KHLOW2008
  • 41,812 POSTS
Hi slim98,
Thank you for the donation.
Your symptoms do not suggest a timing belt problem but rather a battery or power supply problem.
The battery is weak and the alarm has been activated. Use a jumper and you should be able to start the vehicle.
Check the battery voltage and charging rate after you start the vehicle. The battery most probably needs replacement. Check/clean the battery terminal connections
Sep 27, 2008 at 9:51 PM
