1999 Toyota Camry O2 Code Returns
DHOLCOMB65
I have a 1999 Camry, which I love. My check engine light was on and the car wouldn't pass the emission test, I had it checked out and the 1st Oxygen sensor was bad. I replaced it, reset the computer, and it was great! The light went off, and my car passed. This lasted for about 6 hours, then the check engine light came back on. I took it back to the same place, had it tested again. The same code came up, so I thought I got a bad part. I replaced the part again, the light went off, and I thought I was good again. This time it only took about 30 minutes for it to come back on again. I have searched for the answer to this, but does anyone know what would be causing the O2 sensor to go out over and over again? There is no other codes coming up during diagnosis.
Thanks,
Debbie
Jan 4, 2006 at 4:53 AM
  • 55,616 POSTS
This is a difficult problem to detect because the computer can not sense a malfunction, the vehicles computer system thinks everything is ok. In reality what is happening is the electrical component inside the MAF sensor becomes contaminated by air impurities. These containments imbed themselves to the electrical component that senses the air flow causing the sensor to be slightly off, but not enough to trigger the MIL (malfunction indicator lamp). Replace the MAF sensor with a new. NOTE: (Mass Air Flow MAF sensor or Air Intake Sensor AIS, depending on manufacturer. It does the same thing only with different names).
Jan 4, 2006 at 5:42 AM
Suggested Repair
Replace the MAF (mass air flow) sensor with a new unit. Contamination can make it read slightly off without setting its own code, which can cause the oxygen sensor code to return after replacement.
Conversation Summary
The owner of a 1999 Toyota Camry reported a recurring check engine light and failed emissions test traced to the first oxygen sensor. Replacing the sensor and resetting the computer cleared the light twice, but it returned after about six hours and then after about 30 minutes, with the same code and no other codes. The expert explained that a contaminated MAF sensor can read slightly incorrectly without triggering its own fault and recommended replacing the MAF sensor.
