1999 Toyota Camry Need help for my Toyota Camry V6 1999
157,000 MILES • 6 CYL • FWD • AUTOMATIC
CURUNG
My car engine is shaky after I speed it up to 80 mph for about 2 to 3 minutes and slow down to 25-30 mph, but if I speed it up again it still run normally. Fisrt I replaced spark plugs, fuel filter, ignition cables, air filter, and the car run fine for a few days. Now it has the same condition again. If anyone can help me, I would appreciate for your responds
Jun 6, 2010 at 3:01 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 6, 2010 at 8:49 PM
