1999 Toyota Camry Mfgr Code 1133
128,333 MILES • 4 CYL • 2WD • AUTOMATIC
KELLEY.MRPHY
The car failed MD state emissions and I received a mfgr code 1133 an air fuel sensor - do you know where I can buy this part or is this correct part I need for the above code.
Thank you
Jul 14, 2008 at 3:05 AM
KHLOW2008
  • 41,812 POSTS
hi kelley,
From the data that I have, it should be the HO2S (heated O2 sensor) Bank 1.
Jul 14, 2008 at 3:45 AM
KELLEY.MRPHY
Bosch Oxygen Sensor
Part Number: 15733
For Your Vehicle
Vehicle: 1999 TOYOTA CAMRY
Engine: L4 2.2 Liter FI
Universal Type; 4 Wire; Planar; Downstream Sensor; Calif.; Check / Replace Interval: 100,000 Miles
Is this the part I would need?
Jul 14, 2008 at 4:54 AM
KHLOW2008
  • 41,812 POSTS
Hi kelley,
Yes, this part tallies with my data.
Jul 14, 2008 at 5:37 AM
KELLEY.MRPHY
Thanks for all your help. Hopefully can get the part and then have it installed....
Jul 14, 2008 at 5:50 AM
