MAF sensor location
1999 TOYOTA CAMRY
178,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICHARDAH
Where is the MAF sensor located and how do I remove it for cleaning?
Jan 7, 2010 at 3:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
mass airflow meter is located on left side of engine compartment, part of air intake assembly. Here is a guide to help you see how to clean it and the location in the diagrams below:
https://www.2carpros.com/articles/mass-air-flow-service
The four and six cylinders have it in the same place, BTW. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Jan 7, 2010 at 4:06 AM
NADIE
  • 5 POSTS
Once spraying the stuff in the airflow sensor still attached to the airflow meter as we do not know how to take it out. If you could tell us that it would be great. The car will not stay started. It starts and shuts off a real short time after. Any idea's?
Sep 9, 2018 at 9:13 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
What "stuff" are you spraying?
Why do you thing the Air Flow sensor is the problem in the first place?
NADIE
  • 5 POSTS
It was a cleaner that was made for cleaning this sort of thing. I will get the name of it when I can. Also, the reason we did this was that the diagnostics machine came up with this as being an issue. The car was running really sick it would go well then play up. We had the spark plugs changed, fuel filter changed dizzy cap and the rotor button has also been replaced. Trying to find the problem that causes the car to run really rough at times.
WRENCHTECH
  • 20,761 POSTS
What was the exact code number being set?
NADIE
  • 5 POSTS
There were two codes 14 and 24 the airflow sensor and the ECU. Then he reset it and none of them came up.
NADIE
  • 5 POSTS
I just noticed too that I wrote 270 miles should have written 270,000.
WRENCHTECH
  • 20,761 POSTS
I do not know what those numbers are but they are not OBD2 codes and I see no flash codes available for that car. They need to be 5 digit, starting with a "P".
NADIE
  • 5 POSTS
They where what the guy gave us. I just wish we could fix the problem. Thanks anyways.
