What happens is when you turn the ac on it puts parastic drag on the engine and there is a pressure switch in the ac system to notify the ecu when this occurs. The car will shortly dip in engine rpms and then the engine should compensate for the extra load.
I would start by cleaning the throttle body and any idle air control valves present.
SPONSORED LINKS
Thursday, March 5th, 2009 AT 9:04 PM
