1999 Toyota Camry Fuel Pump installation
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
LADYQ
I have a 99 Camry that needs a new fuel pump. I have a friend who is going to do the work for me if i buy the parts. I am trying to figure out if the fuel pump is the only part that should be replaced or do I also need to purchase new seals, gaskets etc. Ive seen fuel pumps with filters and some without and am not sure if the "filter" is the fuel filter or is actually a part of the pump thats needed. Is there anything else I should replace or check while replacing the fuel pump? Any information would be GREATLY appreciated.
Oct 25, 2009 at 10:32 AM
  • 75,988 POSTS
Hi LadyQ and TY for the donation
To start this off Do you hear the fuel pump come on when you turn key to run?? If not-do this block open the flap in the airflow meter and attempt to start -let me know what happened we got a long way to go-
Oct 25, 2009 at 12:09 PM
