fuel filter
SHAYTHORN01
How do you change the fuel filter?
Jul 4, 2009 at 1:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is on the firewall here is a guide to walk you through the replacement with diagrams and instructions below to show you on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jul 4, 2009 at 3:55 PM
BRASCO
Where is it, how do I change it? I am a fairly good parts changer.
Jul 16, 2019 at 3:51 AM (Merged)
  • 31,937 POSTS
Hi there,
Look at the fuel rail where the injectors are.
Follow the large fuel hose to a canister with a pipe fitting on the bottom and a hose union on top. That's it. Now the filter is secured onto the mounting bracket with a 10mm bolt, the bottom pipe union is always very tight so use a good quality pipe spanner to undo, if you round off the nut you will be in trouble.
Mark (mhpautos)
WMBURGE
i want to change the filter but a repair manual says you have to relese the preasure in the line at the fuel pump. i do not know how to access the fuel pump.
  • 31,937 POSTS
Hi there,
It is just as easy to crack the top banjo bolt at the fuel filter to release pressure, just place a rag over the union as this will eliminate any unwanted spray and do it with the engine cold.
Mark (mhpautos)
  • 75,988 POSTS
Do 1-3 below
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_15.jpg
  • 75,988 POSTS
Just the basic tools see below: REMOVAL: Locate the fuel filter on the lower LH side of the engine compartment. EFI Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff1_7.gif
If vehicle has been operated within an hour, the fuel system is probably under pressure and requires caution when removing filter union bolts. Slowly loosen the filter union bolts. Some gasoline may escape, so ensure that the potential for fire is minimized. EFI Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_ff2_2.gif
Remove the union bolts and four gaskets. Loosen filter clamp and slip filter from clamp. INSTALLATION: Slip new filter into clamp. Ensure that flow arrows are in the correct direction. Position filter in the middle of the clamp and tighten filter clamp. Reinstall both union bolts with four new gaskets. Torque union bolts to 13 ft.lbs. (18 N-m). DO NOT overtighten union bolts. Clean any gasoline that may have escaped. Start the engine and check for fuel leaks.
  • 75,988 POSTS
REMOVAL:
1.Locate the fuel filter on the left frame rail in the engine compartment.
CAUTION: If vehicle has been operated within an hour, the fuel system is probably under pressure and requires caution when removing Filter union bolts.
2.Place a shop towel over the fittings and place a suitable container underneath to contain spilled fuel. Slowly loosen the Filter union bolts. Some gasoline may escape, so ensure that the potential for fire is minimized.
3.Remove the union bolts and four gaskets.
4.Loosen Filter clamp and slip Filter from clamp.
INSTALLATION:
1.Slip new Filter into clamp. Ensure that flow arrows are in the correct direction.
2.Position Filter in the middle of the clamp and tighten Filter clamp.
3.Reinstall both union bolts with four new gaskets.
4.Torque union bolts. DO NOT overtighten union bolts.
Torque: 29 Nm (22 ft.lb) .
5.Clean any gasoline that may have escaped.
6.Start the engine and check for fuel leaks.
ANDREW9420
Engine Mechanical problem
1991 Toyota Camry 4 cyl Two Wheel Drive Automatic 220k miles
hi my car runs with LPG for last few years.i never used to drive with petrol.
(ulp)
Am i need to change fuel filter every service.
i didnt change it last two years.thx
KHLOW2008
  • 41,812 POSTS
Hi andrew9420,
Fuel filters are replaced as and when necessary apart from recommended mileages which is about every 30,000 miles.
Oil filter you should replace every service.
DANIELSLEPAK
When I start my car, it revs for a split second but drops and dies, so I have to hold the gas and warm it up before I can release the gas without the car dying. Still it barely holds above 400 rpm, when it should be holding at 1000 rpm. This happened once 4 years ago, and the Toyota dealership replaced my entire fuel injection system. This time I took it to a mechanic who replaced the computer that regulates air and gas flow. I need to replace the fuel filter.
Dec 4, 2019 at 9:44 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
Here is a guide to help you change the fuel filter out step by step with instructions int h diagrams below to show you ow on your car.
PETEBRUK
need to clean idle valve, its stacking after get dirty
DLICCORICE
Transmission problem
1999 Toyota Camry 4 cyl Automatic 140000 miles
i have a 99 toyota camry that starts just fine, until after i press on the breaks, i have to literally floor the gas for it to move. it shifts between gears fine but it just feels like not enough gas is getting to where it needs to go for it to move can you help, it may be a fuel filter right? i was at speedee and the mechanic got into my car and drove it and showed me how to switch between gears for it to move because "he" said my transmission was going bad and i needed a new one but somehow i dont believe him and i think he was trying to shank me out of money because i am a girl
Dec 4, 2019 at 9:46 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Could you elaborate more on the "until I step on the brakes" statement
DLICCORICE
i mean whenever i have to pause or stop, like at a stop sign, stop light, or just to yield into traffic, once i stop the car, i have to literally floor it to get it moving again
DOCFIXIT
  • 18,828 POSTS
Does rpms go way up? If yes maybe trans problem.
When you floor it do you hear any sounds?
Recent tune up? also have fuel pressure checked. But I am inclined to agree with Tech that drove car>
MROZMAT8
  • 10 POSTS
I have issues starting, and it's weirdly not when the car sits for a day or overnight. I have no problem firing the car up in the morning, but it is when it only sits for a few hours or less that when I attempt to start, the engine will crank for [sometimes] up to 5 or more seconds. What could this be? Fuel filter? Starter? I'm at a loss given that it starts fine when the engine is truly cold.
  • 31,937 POSTS
Have you checked for any codes and check fuel rail pressure, when were the plugs last changed?
MROZMAT8
  • 10 POSTS
I haven't checked for codes nor checked fuel pressure. I recently bought the vehicle, and by service records the spark plugs were changed January of 2013. Is there a way I may check these myself if I go to an auto parts store? (i.e. codes and/or fuel pressure).
  • 31,937 POSTS
You can often get a free code read from major auto retail stores, they will not do a fuel rail pressure test.
98TOYOTA
Engine Performance problem
1998 Toyota Camry 4 cyl 151000 miles
I'm trying to replace the fuel filter but i'm having problems with the lower connection of the old filter. It's rusted on really bad and if I end up twisting off and tearing the fuel line at the connection what can I do quickly to fix it?
Thanks
  • 31,937 POSTS
Hi there,
These are one of the hardest filters to change. What i do is remove the top fitting, and unbolt the bracket off the inner guard. Carefully twist the filter & pipe down enough to see the union nut. There is a fair amount of give but be carefully, then using a good quality 14mm pipe spanner and also using a spanner to hold the filter , you should be able to easily undo the fitting, bay be give it a good spray and let it sit for a bit first.
Mark (mhpautos)
PATRICK GILLAN
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic 156K miles
iwas told that my fuel filter is LIFETIME and I do not need to replace it. Do you agree? The car is running great!
BLUELIGHTNIN6
  • 16,542 POSTS
that is correct. there is no service interval for your vehicle's fuel filter. it is supposed to last the life of the vehicle.
TAMBO1022
1998 toyota fuel filter is leaking gas
Dec 4, 2019 at 9:47 AM (Merged)
  • 75,988 POSTS
Wait for it to stop leaking and inspect where its leaking and remove and replace
  • 75,988 POSTS
Let me know the status-this is a fire hazard
