1999 Toyota Camry Flywheel Inspection Panel
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROWETIMO
I'm trying to replace the water pump and timing belt, but can't locate the flywheel inspection panel.
Jul 25, 2009 at 2:51 AM
STEVEW84
  • 673 POSTS
there is no timing mark on the flywheel like there are are on VW's. HTH.
https://images.2carpros.com/forum/automotive_pictures/170495_timing_mark_cam_toyota_1.gif
https://images.2carpros.com/forum/automotive_pictures/170495_toyota_timing_mark_crank_1.gif
Jul 25, 2009 at 4:19 AM
STEVEW84
  • 673 POSTS
the flywheel inspection panel is on the bottom of the engine. But there are no timing marks on the flywheel.
Jul 25, 2009 at 4:23 AM
