1999 Toyota Camry Engine problem
1999 TOYOTA CAMRY
85,000 MILES • 4 CYL • FWD • AUTOMATIC
PRETAGU80
'99 Camry about 85,000 miles.Question guys, check engine light came on awhile back.Sometimes when driving and in acceleration, as much as i'm pushing the gas the car seems to want to go into idle and stay there, though i'm in drive and trying to accelerate. If I then put the gear into park, the rpm needle flutters up and down and the engine does the same. The code it picked up was bad 02 sensor running lean. As it's expensive to replace, I'm wondering does this match symptoms of an 02, or could it be something else? thanks.
Feb 22, 2010 at 8:28 AM
TWINSRAM
  • 42 POSTS
It does sound like the O2 censor, and unfortunatly it could be a number of other things ranging form spark plugs, disributor wires, EGR Valve, Pressure Control Module, Fuel Filter(s),etc. The CHK ENG. light triggers and the symptoms you are experiencing happen with all of these.
Feb 25, 2010 at 12:46 PM
