1999 Toyota Camry engine knock
DRIPHT240
  • 5 POSTS
My friend has a 1999 Toyota Camry CE, 5speed, 155,xxx miles, 4cyl. She recently told me that while coming off the highway the vehicle stalled out... after pop-starting the car to get it back going while coasting, a severe knock from the block or head developed. upon checking it this afternoon the car starts with minimal effort and runs ok but making a very loud ticking/knock. Unfortunately my diagnosis skills are no good for toyotas and we have no idea what it could be. im thinking that because it starts and doesnt shake like its out of time its not the crank or the cam(s). any advice that you can give me as to what the problem is and how it can be fixed would be great.. thanks in advance
Jun 18, 2007 at 10:35 AM
2CARPRO JACK
  • 11,533 POSTS
just because it is smooth doesnt mean the bottom end (crank,rods) arent hurt. Is the noise a slow knock or a fast tapping?
Jun 18, 2007 at 11:03 AM
DRIPHT240
  • 5 POSTS
its a faster tap... being only an amateur mechanic i couldnt give her a definitive answer. Do you know what it is? thanks again for your help!
Jun 19, 2007 at 7:55 AM
2CARPRO JACK
  • 11,533 POSTS
faster tappping noises are usually related to valvetrain.See if you can determine if it coming from the top of the engine or if the noise is louder under the car
Jun 20, 2007 at 1:03 AM
DRIPHT240
  • 5 POSTS
i would say it is definitive that the sound is coming from the top. as soon as i heard the ticking sound i thought it would probably have something to do with the top end.
so would you advise that i take the valve cover off and inspect for any visual damage? and what specifically should i be looking for? any other advise or diagnosis would be great! thanks once more
Jun 20, 2007 at 12:36 PM
2CARPRO JACK
  • 11,533 POSTS
Yes, pull the cover off and look for any of the cam followers that may be loose under the cams.You might want to pull the plugs out so you can turn the engine over by hand to inspect the valvetrain
Jun 21, 2007 at 12:54 AM
DRIPHT240
  • 5 POSTS
ok so ill have to run a breaker bar with addition leverage to crank i by hand, and what exactly is a cam follower? Im not too familiar with the valve train system yet and have not done very much work on them
Jun 21, 2007 at 12:14 PM
