1999 Toyota Camry EMISSIONS TEST
1999 TOYOTA CAMRY
107,470 MILES • 4 CYL • FWD • AUTOMATIC
DENNISVP
I took my mother's car to a smog test/ repair station and it failed. The check engine light had been on for several months. The mechanic ran a diagnostic test and it showed the oxygen sensor was not working properly. The oxygen sensor was replaced 2200 miles ago. He put a new oxygen sensor on and it greatly improved the emissions but still will not pass. He is stumped because another diagnostic test shows everything working properly. The engine sounds and runs perfectly. There is no visible smoke coming out of the tailpipe. He said he has checked all the sensors and functions.
Oct 17, 2009 at 4:00 AM
What did it failed on: HC/CO/CO2/NOX/O2???????????
Oct 17, 2009 at 4:21 AM
DENNISVP
It failed the CO minimum.
Oct 17, 2009 at 4:36 AM
The coolant temperature sensor might be out of calibration not going into closed loop
Oct 17, 2009 at 7:50 AM
