Good afternoon,
No, the piston just pushes back. I attached the procedure and some pictures for you.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
REPLACEMENT
1. REMOVE REAR WHEEL
Remove the wheel and temporarily fasten the disc with the hub nuts.
2. INSPECT PAD LINING THICKNESS
Check the pad thickness through the caliper inspection hole and replace pads if not within specification.
Minimum thickness: 1.0 mm (0.039 inch)
3. LIFT UP CALIPER
a. Remove the bolt and flexible hose from the bracket.
b. Remove the installation bolt from the torque plate.
c. Lift up the caliper and suspend it securely.
HINT: Do not disconnect the flexible hose.
4. REMOVE 2 BRAKE PADS
5. REMOVE 4 ANTI-SQUEAL SHIMS
6. REMOVE 4 PAD SUPPORT PLATES
NOTICE: The support plates can be used again provided that they have sufficient rebound, no deformation, cracks or wear, and have had all rust, dirt and foreign particles cleaned off.
7. CHECK DISC THICKNESS AND RUNOUT.
8. INSTALL 4 PAD SUPPORT PLATES
9. INSTALL NEW PADS
NOTICE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
a. Apply disc brake grease to both side of the inner anti squeal shims.
b. Install the 2 anti-squeal shims on each pad.
c. Install 2 pads with the pad wear indicator plate facing upward.
NOTICE: There should be no oil or grease adhering to the friction surfaces of the pads or the disc.
10. INSTALL CALIPER
a. Draw out a small amount of brake fluid from the reservoir.
b. Press in the piston with a hammer handle or similar implement.
HINT: If the piston is difficult to push in, loosen the bleeder plug and push in the piston while letting some brake fluid escape.
c. Install the caliper and torque the installation bolt.
Torque: 20 Nm (200 kgf-cm, 14 ft. lbs.)
d. Install the flexible hose and bolt to the bracket.
Torque: 29 Nm (300 kgf-cm, 21 ft. lbs.)
11. INSTALL REAR WHEEL
Torque: 103 Nm (1.050 kgf-cm, 76 ft. lbs.)
12. DEPRESS BRAKE PEDAL SEVERAL TIMES
13. CHECK THAT FLUID LEVEL IS AT MAX LINE
Images (Click to enlarge)
Mar 5, 2021 at 2:34 AM
