1999 Toyota Camry Alignment
1999 TOYOTA CAMRY
203,800 MILES • 4 CYL • 2WD • AUTOMATIC
AJACOBSON
Back in the spring I had an alignment done on my camry and now it once again pulls to the right. The tread on my tires are very low, and I'm not quite sure whether it may be the tires that are making the car pull or more of an alignment issue.
Sep 9, 2010 at 8:12 AM
WRENCHTECH
  • 20,761 POSTS
Past experience has told me that unless you have impacted the front wheel hard, it's likely a tire problem. All you have to do to find out is rotate the tires and drive it again.
Sep 9, 2010 at 8:18 AM
AJACOBSON
Thanks!
Sep 9, 2010 at 6:17 PM
