1999 Toyota Camry ABS Light
14,500 MILES • 4 CYL • FWD • AUTOMATIC
SCOOBER74
The ABS light is on constant. My brother-in-law replaced my shocks and said he hit the abs sensor. The light has been on for over a year and I do not have any trouble with the brakes or ability to stop the car. I am wondering if I can simply pull the fuse to make the light turn off. Does anyone know if this is ok to do? Also, does anyone know which fuse it is? I don't have a manual for the car.
Thanks!
Jun 9, 2010 at 4:46 PM
  • 31,937 POSTS
The wheel sensor may well be damaged, if you get a scan done, this will indicate the exact fault in the system, often wheel sensors are at fault, with the check light on your ABS will not work.
Mark (mhpautos)
Jun 9, 2010 at 5:52 PM
