Electrical problem
1999 Toyota Camry 4 cyl Front Wheel Drive Automatic
1) This morning I tried to move the driver's side seat back (my wife drove the car the day before and has to move seat forward) and it would not move back. It moved forwards fine. The back seat portion also moved forward and back. None of these adjustments, naturally helped me. Is it a fuse that is causing the problem?
2) The left passenger window decided about a year or two ago to stop raising the window. The window would go down without issue. The motor would still make noises, but that was it. I tried to check and see what the problem might be but the metal "braces" on the inside part of the door made it almost impossible to get my hands inside to see what the problem was.
May 12, 2008 at 12:34 AM
