1999 Toyota Camry
13,200 MILES • 4 CYL • FWD • AUTOMATIC
TLP
i am having trouble with my rear driver side window. you can hear the motor run when you push the button; however, the window will not go up or down. what do i need? regulator? motor? the window can move freely or by hand and there is a noise in the door when i shut it.
thanks
Jul 21, 2008 at 4:55 PM
BMRFIXIT
  • 19,053 POSTS
I would remove the door panel and check if glass is off the regulator rail
most likely regulator no good
Jul 22, 2008 at 12:07 PM
