1999 Toyota Camry How do I remove the plastic tail light assemby cover in the trunk in order to replace a brake light bulb?
Oct 30, 2007 at 8:28 AM
SERVICE WRITER
✓Experienced Mechanic
The lense does not come off, the whole unit will. Look in the trunk and pull back the felt lining and look for mechanical fasteners that need to be removed.
Oct 31, 2007 at 12:53 PM
LOSTINMARS
yep, there should be 4 8mm or 10mm nuts holding it on.
