1998 Toyota Camry Wet Sensor
206,000 MILES • 6 CYL • FWD • AUTOMATIC
GLEN5546
While driving my Camry I drove thru some water during a storm. Some type of sensor or relay appeared to get wet. The tranny started to stutter after stopping and then when shifting into 2nd appears to disengage entirely with no movement and high rpm. The car dried out and went back to normal after 2 days. It just happened again 1 week later after getting wet. This time the car will not engage at all when started and put into gear. I was able when it first got wet to turn the car off and restart, resetting the relay and the car would engage for a short run then disengaging again. Now the transmission fluid smells burnt. Not sure if its because I overheated transmission by pushing the car to try and drive it home as I was stranded with my 2 kids. Now I am worried if this will happen every time the car gets wet too. Even after its fixed!!!
Jul 28, 2008 at 8:12 AM
KLSHIEL
  • 163 POSTS
It definatly sounds like an electrical problem, if not a sensor the wiring harness connectors may be bad and not providing a good connection when wet. You may end up with other transmission problems after getting it fixed due to burned up parts. I would start by getting the transmission fluid changed so you don't ruin it further. If the transmission operates without trouble other than when wet it should be worth getting the electrical fixed.
Jul 28, 2008 at 8:34 AM
