1998 Toyota Camry water pumps leaking
DONZEL
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic
I have 92,000 miles on 98 Camry 4 cylinder - just learned my 3rd water pump is leaking. Bought car new - always have it serviced on time - Each water pump had a very slight leak - at 34,000 miles and the 2nd at 59,000 miles and now the 3rd at 92,000 miles. Is this a problem with 98 Camry - can I add something to radiator to prevent this - is a sealer possible? thanks
Jul 9, 2008 at 4:49 PM
BLACKOP555
  • 10,386 POSTS
whers lit leaking? the pulley? the mating surfaces? where.
could be subpar parts if its the pump itself leaking, or your mounting flange could be warped.
Jul 10, 2008 at 1:29 AM
