1998 Toyota Camry trouble shoot
402,168 MILES • 4 CYL • 2WD • AUTOMATIC
TKESMOM
car gets hot and fan does not come on. lower hose stays cool while upper hose gets hot.
Jan 15, 2009 at 4:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Your coolant flow comes out of the engine through the upper hose, into the radiator. The lower hose is cooler because the radiator has done its job...nothing wrong here. You need to test your relays/fuses and also inspect wiring to cooling fan. Cooling fan relays are located under hood (pictured below).
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_142.jpg
Post results of inspection and I will follow up. Hope this helps.. Thanks for using 2CarPros.com!
Jan 25, 2021 at 4:39 AM
