1998 Toyota Camry Timing Belt
108,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAKMCA03
Dear Sir,
I bought this car 2 weeks back but the owner is not sure if timing belt need to changed. And he is also not aware if the previous owner changed the timing belt. Hence could you please help me with the following:
1. How to know if timing belt is changed?
2. For Toyota Camry, when is the ideal time (at what mileage) to change the timing belt.
Thank you very much for you help and time.
Oct 4, 2009 at 12:39 PM
  • 75,988 POSTS
It should be replaced at 90,000 miles its past due at your present mileage. Replace it
Oct 4, 2009 at 12:47 PM
