1998 Toyota Camry suspension
148,653 MILES • 4 CYL • 2WD • AUTOMATIC
ALLWAYSBROKEN
When I hit any size bump I hear a noise from the right front end. Sounds like wheel bumping. I had it up on a lift and could not find anything loose. Please help.
Jan 5, 2009 at 1:57 AM
MMPRINCE4000
  • 8,548 POSTS
Raise front, put on stands, grasp wheel and push/pull both horizontally and vertically, looking for any movement, if there is then look at ball joints, tie rods, control arm bushings, struts and bearings. Also inspect motor mounts.
Jan 5, 2009 at 2:09 AM
