1998 Toyota Camry struts
SHAFER
Suspension problem
1998 Toyota Camry V6 Two Wheel Drive Automatic 93000 miles
Can you tell me if anything goes wrong with the car if the struts are not replaced when recommended? thank you
Dec 6, 2007 at 6:38 AM
  • 31,937 POSTS
Hi there,
If you drive with faulty suspension struts you will experience wandering steering, unstable ride (over bouncy) excessive tyre wear and braking distance can also be affected. If struts are faulty it is advisable to have them replaced.
I hope that this is a help to you.
Mark (mhpautos) :D
Dec 6, 2007 at 7:35 AM
