1998 Toyota Camry Shift totally loose after putting in park
1998 TOYOTA CAMRY
89,745 MILES • 4 CYL • FWD • AUTOMATIC
CIGGY629
Last night i stopped my car and put it in park..felt it go loose...tranny is in park....shift on console is totally loose no engagement?
Nov 27, 2008 at 4:48 PM
MMPRINCE4000
  • 8,548 POSTS
Check the cable at the trans. it may have come loose or the retaining clip broke, or bracket at trans. broke.
Hold down bracket in the console may have broken.
Inspect the cable connection at the trans. first and retaining clip.
Nov 27, 2008 at 10:13 PM
CIGGY629
The cable to the tran was off, so the retaining clip broke
The mechanic wants to replace the cable and clips
Nov 28, 2008 at 7:49 AM
MMPRINCE4000
  • 8,548 POSTS
The only reason you would replace the cable is if the cable is bad or the place where the clip holds it in place is worn, otherwise, replace the clip.
I would have him inspect the motor mounts, see if there is excessive movement, that caused the cable clip to fail.
Nov 29, 2008 at 12:07 AM
