1998 Toyota Camry Rear suspension makes thumping noise when
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
JB70914
Rear end makes noise when going over a bump suspect rear struts. Could you give me repalcement instuctions and recommend replacement local autoparts store has 2 levels of Monroes to replace with?
Mar 17, 2009 at 12:43 AM
GRSMNKY
  • 33 POSTS
before shelling out for struts, check rear stabilizer links and bushings. they wear out/dry out rather fast and can make the noise you are hearing.
Mar 17, 2009 at 3:17 PM
