1998 Toyota Camry Rear brake rotor removal
140,000 MILES • 6 CYL • FWD • AUTOMATIC
CAHWYMAN
Trying to remove the left rear rotor but it's stuck at the top of the rotor. The right side came right off but the left is stuck. The E brake is off and those E brake pads are depressed. It seems like its stuck on the E brake assembly. Any suggestions?
Paul
Jun 5, 2010 at 9:42 AM
KHLOW2008
  • 41,812 POSTS
Hi cahwyman, Thank you for the donation. If the E-brake is holding the rotor from being removed, you need release the shoes by using the adjuster. The adjuster can be accessed by the rubber plug and is located at bottom.
https://images.2carpros.com/forum/automotive_pictures/192750_RearBrakes98CamryFig08_1.jpg
Mar 5, 2021 at 2:34 AM
CAHWYMAN
KHLOW2008
  • 41,812 POSTS
You did not write anythng, is there anything that we can do to help?
Just use the reply to question link without the quotes would do, unless you want to refer to something to our replies
