1998 Toyota Camry oil light
151,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHN BUCKNER
my 1998 toyota camry oil light came on and it was low on oil. I put 3 q in engine and check dip stick which seems to read ok but my oil light is still on it did go off for a short time 15 min. but now stays on. engine runs find thank you for your time
Jan 15, 2010 at 9:50 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal c ould mean oil pump and engine bearings
Jan 15, 2010 at 9:54 AM
