HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Climate Control
Heater
Not Working
SPONSORED LINKS
NO HEAT
DSFILLIAN
MEMBER
1998 TOYOTA CAMRY
I have very little heat. The fluid is fine, but no heat?
Sunday, November 29th, 2009 AT 4:11 PM
MECHANIC
Check thermostat could be stuck open, heater control valve function and clogged heater core. Use this guide to see whats going on
https://www.2carpros.com/articles/car-heater-not-working
SPONSORED LINKS
Tuesday, March 16th, 2021 AT 6:59 PM
OIDAVEY
MEMBER
0 POST
I had this problem it was the thermostat stuck open, all fixed! The guide is great!
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1998 Toyota Camry Heater
What Makes Ur Heater Boo Cold Air.
Asked by
jeannesmith
1 ANSWER
1998
TOYOTA CAMRY
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Heater Blowing Cold Air?
When I Turn On The Heater, It Blows Cold Air, Temp Guage Is In Normal Range, Just Happened About 4 Days Ago. Thanks
Asked by
jerryjones65
1 ANSWER
1998
TOYOTA CAMRY
My Heater Only Works When Car Is Not Moving
I Have To Start Car And Let Temp Go To Normal. My Heater Only Works When Car Is Not Moving. Once I Start Moving Temp Goes Back To C, And...
Asked by
trellckc
1 ANSWER
1999
TOYOTA CAMRY
2003 Toyota Camry No Heat
Just Noticed That The Heater Is Not Working.(At All) 1-a/c Is Fine 2-no Apparent Leaks 3-no Smell Of Antifreeze 4-the Thermostat Gage Is...
Asked by
skip11
2003
TOYOTA CAMRY
1989 Toyota Camry My Heater Doesn't Work
My Heater Hasn't Worked For A While And I Was Wondering What The Name Of The Part I Need To Fix It Was. The Part That Is Malfunctioning Is...
Asked by
canine224
1989
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Heater Not Working
How to Replace Damper Door Switch
Blend Door Actuator Replacement
Online car repair manuals
