1998 Toyota Camry lights
175,000 MILES • 4 CYL • FWD • AUTOMATIC
just yesterday my lights in my trunk lid went out all of them the back-up lights the license plate light the tail lights. all the other lights works i checked and change the fuse. the bulbs are good. any help thanks in advance dave
Apr 1, 2009 at 8:11 AM
GRSMNKY
  • 33 POSTS
check the wiring loom in the trunk on the left side close to the trunk hinge. I've seen many wires break at this point due to constant flexing while opening/closing the trunk. Inspect the wires inside the loom at this point closely for broken wires. good luck
Apr 1, 2009 at 2:24 PM
thanks i checked the wiring at the trunk hinge everything checks out o.k. any other ideas. thanks dave
Apr 1, 2009 at 3:07 PM
WILLIAM OLIVER
  • 25 POSTS
re check the wires in the trunk left side ck white, red and green wire in this harness ...
Apr 2, 2009 at 12:09 AM
