1998 Toyota Camry leaks
195,000 MILES • 4 CYL • FWD • AUTOMATIC
FAWNIE2
i am having my transmission leak, oil leak fixed (new seals) on my car. also new struts, timing belt, brakes, alignment, and transmission flushed. I also have put a new starter, pcv valve, spark plugs, wires, air filter, oil filter recently done as well. Is there anything else I need to do in order to have my car in great running shape. I also have basically new tires on the car as well. I don't have a maintenace schedule for mileage of 195000 to review. Is there anything else that I should do?
Dec 8, 2008 at 1:59 PM
  • 31,937 POSTS
Hi there,
May be get the valve clearances check, you could have the injectors serviced and run a scan just to make sure all is fine, otherwise you are on top of it.
Mark (mhpautos)
Dec 8, 2008 at 2:57 PM
