1998 Toyota Camry ignition
LINCOLN5
Other Category problem
1998 Toyota Camry Engine Size unknown Front Wheel Drive Automatic 175,00 miles
My son's 1998 Toyota Camry was working fine. He parked the car, ran into a store and when he came out and attempted to start the car, it wouldn't work. The key goes into the ignition switch and only turns far enough to enable the radio to turn on but it won't turn far enough to let the car start.
Jan 25, 2008 at 10:11 AM
DJMALISK
  • 6 POSTS
[quote:0b6f4358ae="lincoln5"]Other Category problem
My son's 1998 Toyota Camry was working fine. He parked the car, ran into a store and when he came out and attempted to start the car, it wouldn't work. The key goes into the ignition switch and only turns far enough to enable the radio to turn on but it won't turn far enough to let the car start.[/quote:0b6f4358ae]
When you put the key in ignition, after you turn the key try to move the steering wheel left - right, could be that, that your son is not able to start the car! That's the only thing i could think of ....
good luck
Jan 28, 2008 at 5:03 PM
