Smell of mold in the car, windows fog up when heat turned on and the bottom vents do not work. Help!!!
Jan 5, 2008 at 7:35 AM
✓Experienced Mechanic
Hi there,
Have the drain tube for the A/C checked for a blockage, you can buy automotive mold & mildew treatments for the A/C system form your parts supplier. You will have to inspect the splitter control , Check that the controller is not very loose or very tight, this may be a job for your mechanic. But you can do the mould treatment.
Mark (mhpautos)
Jan 5, 2008 at 8:32 AM
