Gear selector light?
120,000 MILES • 4 CYL • FWD • AUTOMATIC
HELEN_JOHN2
The light that shows which gear you are in, on the transmission hump, has burned out. Is there an easy way to get under the indicator panel and replace the lamp?
Mar 18, 2010 at 1:27 PM
MMPRINCE4000
  • 8,548 POSTS
You will have to remove the console gear cover to get to light. Here are the instructions on how to do the job. Check out the images (below). Let us know if you need anything else.
Mar 19, 2010 at 12:43 AM
HELEN_JOHN2
Any clue as to HOW?
Mar 19, 2010 at 2:51 AM
MMPRINCE4000
  • 8,548 POSTS
Use a small standard screwdriver to pop the cover off, and then you can get to the bulb. You may need to remove the shifter mounting bolts to help gain access.
Mar 20, 2010 at 1:08 AM
