1998 Toyota Camry fuel pressure regulator
KATIE OLIVER
Engine Mechanical problem
1998 Toyota Camry 6 cyl Front Wheel Drive Automatic
1998 toyota camry I would like to kno how to put a fuel regulator on my car i was told it is the regulator it self. How do you put a fuel regulator on a 1998 toyota camry
Jun 2, 2009 at 7:58 AM
KHLOW2008
  • 41,812 POSTS
Hi Katie Oliver,
The fuel pressure regulator is a remove and plug in item and replacement is rather simple.
Remove the return hose and 2 holding bolts and it can be removed by twisting it out.
Jun 6, 2009 at 4:19 AM
