HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Fuel System
Fuel Injector
Replace/Remove
1998 Toyota Camry fuel injector
DESPERADO4
MEMBER
1998 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
159,000 MILES
How hard is it to change one of the fuel injectors in the camry? And do you know a easy way to do it if it is a pain?
Thursday, June 19th, 2008 AT 5:10 PM
KHLOW2008
MECHANIC
Hi desperado4,
Release fuel pressure first.
Disconnect injector wire sockets
Remove the fuel rail after removing holding bolts and pull the injector out.
Sounds easy right? ;)
Friday, June 20th, 2008 AT 11:22 AM
Please
login
or
register
to post a reply.
Related Fuel Injector Replace/Remove Content
1999 Toyota Camry Hard Start After Replacing Fuel...
I Recently Replaced The Fuel Injectors On My V-6 Solara Due To Intermittent Running/missing Problems. The Dealer Had Looked At The Car A...
Asked by
dkellogg56
1999
TOYOTA CAMRY
GUIDE
Fuel Injector Replacement
Part of the fuel injection system a fuel injector is reasonable for allowing fuel to enter the engine which is controlled by the car's computer. Various sensors provide...
1992 Toyota Camry Fuel Injectors
My '92 V-6 Camry Has A Fuel Flooding Problem. I Have Isolated It To The The Number Four Fuel Injector. I Have Checked With A Noid Light...
Asked by
Ken Brown
1992
TOYOTA CAMRY
1999 Toyota Camry Leaking Fuel Injectors
Engine Problem 1999 Toyota Camry Front Wheel Drive 186000 Miles I Own A 1999 Toyota Solara. I Had Problems With The Check Engine...
Asked by
Pharris68
1 ANSWER
1999
TOYOTA CAMRY
Cleaning Fuel Injection System On 2000 Camry Le
My Car Has Been Hesitating Very Badly. A Friend Recommended That I Put Lucas Fuel Injector Cleaner In The Tank To Clean The System. I...
Asked by
suttles95
2000
TOYOTA CAMRY
95 Toyota Camry Possibly Flooded.
Make: Toyota Model: Camry Year: '95 Mileage: 155,000 Engine Size: 4 Cylinder [automatic] My...
Asked by
kingofhearts
1995
TOYOTA CAMRY
VIEW MORE
Misfire
Intermittent Misfire
Misfire Random Code P0300
