1998 Toyota Camry Front Passenger Door
162,680 MILES • 4 CYL • FWD • AUTOMATIC
JDCFOX
It won't open from the outside but will from the inside, it will lock if you use the button on the drivers side but if you flip it manually, it will not lock, this morning, I rolled down the window and the door popped open. How do I fix this?
Dec 11, 2007 at 5:27 AM
MERLIN2021
  • 17,250 POSTS
Inside a door there are thin steel rods, made to connect the handles to the latch, take off the trim panel and look to see which one is flopping around, it may need a new clip and striaghtening!
Dec 14, 2007 at 9:24 AM
