Hello, what does it mean when your engine light comes on? What are the possibilities of problems that could exist?
Wednesday, June 24th, 2009 AT 5:20 AM
MECHANIC
It means there's trouble within the engine management system -you need to have the computer scanned for OBD2 code/s to find out why -what's causing the light to come on.
SPONSORED LINKS
Wednesday, June 24th, 2009 AT 5:27 AM
MECHANIC
Hi there,
The light is a visual indication that there is a set fault code in the ECU, a scan will give you the fault code and with this you can start the diagnosis process, get the scan and report the code here first.
