1998 Toyota Camry Engine light
RANDYHUFF2
  • 1998 TOYOTA CAMRY
  • 6 CYL
  • 70,000 MILES
My car just turned 70,000 miles and now the engine light is on, all the fluids are fine and the oil has been changed recently. Any thoughts? I heard that Toyota has a timed engine light display.
Monday, November 24th, 2008 AT 8:00 AM
DSPLC
  • 220 POSTS
To get an idea of what is "Check Engine Light", please click the link below.
https://www.2carpros.com/dia/how_to_scan_trouble_codes.htm
I know Autozone (Auto parts store) can get the DTC (Diagnostic Trouble Code) of your car for free. They have an OBD II Scanner in which they will connect underneath between the brake pedal and steering wheel. Ask for the DTC code which is usually starts at "P" and followed by numbers. Usually, Autozone employee will tell you what it means and what needs to be replaced or you can post another topic here with the DTC code and members here will help you.
Monday, November 24th, 2008 AT 11:06 PM
