Will it not open at all or will it not open from inside or outside?
Nov 5, 2009 at 1:22 PM
TIFFSIG1970
MEMBER
Nope, it will not open at all from inside or outside.
Nov 6, 2009 at 1:33 AM
STEVEW84
✓Experienced Mechanic
Your going to either going to have to get the door panel off and open it manually or slim jim it(if that works) to get the door open. Then figure out what the problem is. The door panel might break a little since the door is closed.
Nov 6, 2009 at 1:40 AM
TIFFSIG1970
MEMBER
I have tried the slim jim and I would have to totally break the panel in order to get it off.
Nov 6, 2009 at 1:45 AM
STEVEW84
Did you take the screws out already?
Nov 6, 2009 at 2:02 AM
TIFFSIG1970
MEMBER
I can't get the screws out they are some that can't get out when the door is closed.
Nov 6, 2009 at 2:05 AM
STEVEW84
There are two screws in the arm rest. A screw behind a little cover by the door handle, then you have to take the bezel off. Then just have to pop it off. If you need pictures of how to do it just give me your e-mail.
Nov 6, 2009 at 1:37 PM
TIFFSIG1970
MEMBER
I know about the screws in the arm rest, but I didn't know you could take the panel off by just taking them out. My email address is tiffany.sigala@phoenix.gov. Please send me that picture.
I can't open the door. I know how to get the panel off with the door open. I need the panel off with the door closed. Then I need to figure out how to open the door.
